Adds a member VLAN to a translation VLAN.
| vlan_name | Specifies the name of the translation VLAN to which you want to add the member VLAN. |
| member_vlan_name | Specifies the member VLAN to be added to the translation VLAN. |
| port | Specifies the port that serves as the loopback port. |
| loopback-port |
If two or more member VLANs have overlapping ports (where the same ports are assigned to both VLANs), each of the member VLANs with overlapping ports must have a dedicated loopback port. |
N/A.
This command configures VLAN tag translation between the two VLANs specified. The member VLAN is added to the list maintained by translation VLAN. A translation VLAN can have multiple member VLANs added to it.
The following example adds member VLAN leafvlan to the translation VLAN branchvlan:
configure branchvlan vlan-translation add member-vlan leafvlan
This command is available on all platforms that support the VLAN Translation feature. For features and the platforms that support them, see the Switch Engine v33.1.1 Licensing Guide document.
